Newbie help for first mirrorless camera
Gilgameshuk
Contributor
Hello there,I'm trying to find what Mirroless camera do you recommend
Conditions are :Has to be A sony
Has to be the cheapest possible but mirrorless
Must do full motion video 1080P and above
has to be able to fit a microphone to it or facility to use a WIRELESS mic.
The reason is I need one to review various products for my Sony Tech reviews channel
Any suggestions please?
Gilgamesh the first ONE and ONLY King
11 REPLIES 11
Mick_D
Moderator
Hi @Gilgameshuk
You should probably look at the the HX400V. At under £350 it's about as cheap as they come but you should be able to do everything you need with it.
Mick
madge115
have a look at the sony  a-6000  or  sony-5100 mirrorless  all the best   madge115
Gilgameshuk
Contributor
Thank you ever so much
kenthomson
The issue with most cheaper cameras (of all brands) is that they do not have a socket to plug in a microphone, wired or wireless.
Sony makes a Bluetooth microphone that is compatible with cameras using their MI (multi interface) accessory shoe. Not sure if it's compatible with all MI cameras, but it does work with the A6000 model. The newer A6100 has a mic socket and at the MI shoe.
The BT mic system is called the ECM W1M Wireless Microphone System, can't find it on the Sony webpage right now so maybe it's discontinued. Here's a short video test of the mic -
https://www.youtube.com/watch?v=bh1w5wtJS9w
Gilgameshuk
Contributor
ah thank you
This is exactly what I wanted, as I will be presenting videos for my Sony Xperia Tech Reviews YT channel
Thank you very much for this, ill get a second hand a6000 to start off with and find this solution on Fleabay (mic)
kenthomson
A6000 is a solid choice, you’ll like it. Jessops are selling their ex-display models at £350 including lens -
https://www.jessops.com/p/sony/a6000-mirrorless-camera-in-black-16-50mm-power-zoom-lens-ex-display-1...
Gilgameshuk
Contributor
Will be purchasing one, once lock down ends
and the wireless mic system also.
Plan on reviewing all sony products but concentrating on Xperia phones.
madge115
the sony a-600 is very good choice but do ask about others in the sony mirrorless range as sony has a very good range a good camera shop will put you on the right road  i wish you all the best on your selection                                        madge115
Gilgameshuk
Contributor
cheers
I am debating between A used A6000 or A6100 from Jessops (i would go directly to my Sony  Centre in Leeds however they only sell new)
I understand that the A6000 Has no in Built ois, however the 6100 does?
