From what I understood.
Go to Menu then the 2nd page/tab "Setting" which is next to the Camera icon then page 3 and option 3
its called "Flexible Spot Points" change it to "15 Points" see if thats what you are looking for...
Thanks but no it isn't. All that does is change it from 79 available points to 61. Not 100% sure why you'd want to reduce the number tbh unless people want consistency as some lenses only use 61 points.
There's an option to display the AF points or not in wide AF, but not flexible spot which seems very odd to me. I contacted Sony about this to see if they could add this feature in an update and they passed it on to the relevant department. I'll not hold my breath, although I guess if enough people like me who try to stick to cross type points contact sony about this then maybe they'll add it. Still seems odd to me as surely you'd want some sort of reference as to which point you're on as I'm sure I'm not the only one who tries to use cross type where possible?
The 79 to 61 that you are talking about is this one.
The one I am talking about is below that which is 3rd if you change it from "All" to "15 Points" you will get the single spot along with other dim focusing points which you could than move with your joy stick its same as "local"... Note for that you have to set the focusing on Flexible Spot not Expandable
Thanks but all that does is limit the amount of points you can use. If you look at the setting below that one "Wide AF area points" and toggle this on and off and see what effect this has when shooting in wide AF, this is what I want for flexible spot. I want it to display all AF points in the background with the selected one highlighted, this way I know which spot I'm on and whether or not I'm on cross type.
I totally understand what you are trying to say and what you want but I think if any person who has used A77 can easily remember and switch between different focus points without being them displayed on LCD. I do macro photography of insects its usually high magnification like 4X plus which makes DOF very very shallow, all I do is keep the focus point in center and after locking my focus on area of intrest I move the camera accordingly to frame my shot the way I want. You can easily work with one focus point I never had a problem specially A77ii with its new focusing system because the tracking "Square" works better than before. Having 79 focus points displayed on screen is "in my understanding" not much pleasing because in some light situations the focus points do hide the important details of the image. Thats why they have this option called "AF Area Auto Clear" which clears the af points when focus is locked so you could see better. I really dont understand what you are trying to achieve with that feature. But as far as remembering the focus point position is concerned your best choice so far is to Put the focus mode on Expand flexible spot which would give you an idea where your focus point is along with other 8 dim/small focus points around it. you can also estimate the focus point position from the grid/border lines of the focusing area on LCD. Other wise my dear just hope that sony enabels it according to your wish in next FW update.
Thanks for your reply and trying to help it's much appreciated, although I do think you are missing my point to a certain extent. FYI I too do macro, but I wouldn never use AF for such shallow DOF. MF and focus peaking is all I use.
Anyway, back to the AF markers. Expandible flexible spot does not help my issue either.
Let me clarify my point. With the A77 the grid marking the AF points was visible at all times, I could therefore frame my subject, move the AF point to the closest cross type AF point to my subject and then recompose if necessary. Usually recomposition wasn't necessary as the cross types were well spread. With the A77ii the AF point grid is not visible so as I move the flexible spot point around the frame to focus on the subject I have no way of knowing whether I'm on a cross type or not. I'm too busy framing the subject not counting how many moves across and up/down I have made with the AF point. With the A77 you didn't have to count as the AF grid was there and I could just look where I was and see whether I was on cross type or not. I usually work with shallow AF so the focus point had to be accurate which is why 99% of the time I use spot (local) rather than wide or zone. Also, due to the shallow DOF it's not always a good idea to recompose too much, so using centre point and then recomposing can often mean you've moved out of the plane of focus.
Hopefully you can see now what I'm trying to acheive? If not tell me this, when you're composing a shot using single point AF (flexible spot) do you instantly know if the AF point you're on is cross type or line? I don't just by looking. At the moment I'm having to use the various icons around the screen as a reference and draw mental grids across the screen to know if I'm on cross type or not. Horizontal's not too much of an issue as they're only spread across the central zone, but vertically is a little more challenging as they are every other line, and without a reference grid it's hard to know which line/row you're on.
I personally don't think the smaller sqauares of the AF grid are distracting when framing the shot. However, I do see that some might which is why it would be nice to have the feature to turn it on or off. On for those like me who instantly want to know which AF point they're on and so know if they are on a cross type or not, and off for those who do not want the disctraction.
I know every one shoots differently and not everyone will want the AF points displayed, but as I've already mentioned they already have this option for wide already, so why not spot too? As I said, this seems odd to me. I have emailed Sony so time will tell if they add it or not. If not I will have to continue mentally draw grids.
It's not the end of the world by any stretch, and in good light I'm not too bothered whether I use cross type or line. However, in low light I'd rather stick to cross type and then I know AF will be more accurate. Oh, and I don't use subject tracking per se. Quite often I want to pin point an eye for example and the tracking square is too large an area.
The grid I am talking about is the one that covers Af points up and down.
and I don't limit my self to one style only I change my methods according to situations, like lighting, angles, position of my setup. Also im not a good manual focuser when it come to catch a flying bee or butterfly. my very first camera was with AF. & yes i can easily remember the cross type AF points, & I dont understand why can't you??? I mean being a macro photographer why are you having such a hard time remembering the cross types Af points they are only 15 and are in the center area.
The above is from Sony A77ii brochure. greens are Cross Types...
and by the way do you have any online space where you share your photography skills you write like an expert.
Yes I understand all that, and yes I can remember where the cross type points are. But say I move away from the centre point am I up one line, 3 lines etc. It's not easy to tell as the AF you've selected is just somewhere in that space, there's no reference point. If every time I compose I count, for example move left one and up 2 I know I'm on a cross type. However, If I'm just moving the AF point around without counting it's not isntantly clear whether I've moved up 2 or 3 etc as the points are so close together.
I don't have my camera on me at the moment to show a screen shot, but I'll try to remember later so I can show what I mean. That first grid does not show the AF points up and down, only the 8 points around the selected point, and as pointed out I don't use expand flexible spot.
And lol at your comment about me writing like an expert, I'm merely answering your replies.
So to clarify again. Yes I have memorised where the cross points are, but when using flexible spot and moving it around it is not instantly obvious to know if I am on those cross points as there's no reference point to know whether I've moved up 2 lines or 3 lines for example. You have to keep referring back to the centre point to then see how far you've moved.
As I previously said, it's not a big deal, it would just make it nicer and quicker to use if I could toggle the grid. Unfortunately through this rather lengthy discussion it now looks like a bigger deal than it actually is.
Just to finish off it would be nice actually if the A77ii did what my Olympus Em10 does. As you are moving the AF point around all the AF points are displayed. As soon as you stop moving the AF point around all the other points disappear and you're just left with the one you've selected. This way you know instantly which point you've chosen without having to count all the time, and then it's not blocking your view whe composing.
I'm going to leave this discussion now as it's going around in circles.
I was about to say the same thing lolz its not going around in circles its going "spherical" have a great time buddy we all learn with time somtimes easy way some times the hard way. So keep learning & it would've been great if I could see your photography work but no worries
BaBye
