Sony Alpha cameras 25p over HDMI
videosoul
It is shocking and bizarre Sony's Alpha cameras cannot output 25p over HDMI.
When the camera is in PAL mode and the internal recording is set to 1080p25 the HDMI is always either 1080p50 or 1080i50.
However if the camera is in 24p more then 1080p24 is possibe!
This, as far as I (and my of my peers and colleageus) am concerned is totally nonsensical.
I'd love to have a really meaningful response (not some sort of vague Customer Service "oh that's just the way it is") from Sony as to exactly why this is the case. Is it some sort of strange hardware limitation? Could it be fixed with a firmware update? Will new forthcoming Alpha cameras also have this hinderance? Why do Sony not feel this is important?
Surely it goes without saying that the HDMI output is commonly used not just for monitoring, but also for recording to external recorders. As such, one needs to be able to record the same base frame rate as the internal recording (and even if only recording externally, 25p needs to be supported as it's one of the main international standards!).
1080p selected as the HDMI output.1080p selected as the HDMI output.
25p internal selected (HD 1080p25).25p internal selected (HD 1080p25).
But, as reported by a Sony LMD-A170 (for example) the signal is actually 1080p50!But, as reported by a Sony LMD-A170 (for example) the signal is actually 1080p50!
12 REPLIES 12
ripvanmarlowe
The whole point of this thread is that Sony does not offer this option. We are asking for them to include it. It's not a broken feature, it's a feature that should exist that doesn't.
Win_88
Specialist
Hi @ripvanmarlowe
My bad, I got confused and thought you're facing issues with 24p which is available: https://helpguide.sony.net/ilc/1640/v1/en/contents/TP0001297278.html
I raised this as feedback to Sony. Right now this is all we can do about it.
You can always sent a ticket to customer support with any feedback or feature suggestion you have: https://services.sony.co.uk/supportmvc/en/Contact/Email
Win_88
edkmedia
Using the A7IV with the latest firmware (v3.01) and still don't have the option to output 1080 25p via HDMi. What's even more infuriating is it gives that option if you stream via USB-C, but not HDMi. Go figure. Sony, please add this feature to 1080 as you have done for 4k output.
