2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
Brigante01
Not sure which model you have in mind having 100ms response time? I'm using the 43X830C as my main computer monitor and at 4K 4:4:4 I've never had a problem with input lag on any type of game.
It might not be the monitor for you if you're a competitive FPS gamer but for anyone else it's perfectly fine.
Shodney
I've got the 850C, which is just short of 100ms (see measurements at
http://uk.rtings.com/tv/reviews/by-usage/hdr-gaming/best ).
The 830 doesn't have HDR, which seems to be what pushes it up.
Brigante01
That sounds like a probable explanation! I went for the 830 because of the low input lag.
If they could just sort out the 4K judder then it be pretty much perfect for me.
Not applicable
Dear all
This thread is now CLOSED !
If you would like to continue a discussion, please do so in the following thread:
https://community.sony.co.uk/t5/the-lounge-room/android-tv-discussion-thread/m-p/2233333
If you have issues or problems, please create a new thread on the Android TV board:
https://community.sony.co.uk/t5/android-tv/bd-p/Android_TV
Note: Due to a lithium forum restriction, this massive thread cannot be moved at the moment.  A support ticket has been raised and when resolved, it will be moved to the Android TV board.
