KD-55A1 - Dolby Atmos with Netflix?
jonnyaikido
I have a KD-55A1 connected via a 2.1 HDMI (ARC) cable to STR 1080DN amp with connected 5.1.2 atmos speakers.  How can I get the Netflix app on my TV to stream Dolby Atmos audio to the AV amp?
Thanks!
61 REPLIES 61
hikotam
Hello
See this link please
https://developer.dolby.com/technology/dolby-audio/dolby-truehd/
I believe you were able to get dolby atmos via Dolby TrueHD. Meta data about dolby technologies are displayed in different ways in different audio equipment.
hikotam
Also, please check if your HDMI output on TV is set to correct one like Arc and HDMI signal format for the port connecting to soundbar should be Enhance 4k HDMI signal format
I would suggest test the entire set up watching a movie like Dunkirk on netflix. Turn up the volume little bit higher than normal and use correct subwoofer settings, you should be able to feel the dolby atmos experience
