KD-65XF8577 Wired LAN shows not connected.
profile.country.GR.title
djdreamo
I have the Android TV KD-65XF8577 and suddenly the wired LAN shows not connected and no link on the network switch. WiFi is working fine.
TV has the latest update Firmware update v6.6575 which supposed to solve a problem with the wired LAN but mine instead stopped working....
I have installed from play store an app which checks the Ethernet on your Android TV and the eth0 which is the wired LAN is detected but shows that status link is down.
I have checked the LAN cable and is working fine on my laptop but not on TV.
Any help will be appreciated
6 REPLIES 6
Please set the clock of your TV to network time - this should solve the issue.
djdreamo
Thanks for your reply.
I have already check that and it is already set to network time.
And the firmware is the latest which supposed to fix the time-network issue you are mentioning.
In any case that is not my case
Thanks anyway
profile.country.IT.title
rooobb
Your status seems more related to a network setup issue (i.e. IP conflict?) ...
djdreamo
No it is not a network setup. TV network is set to DHCP.
Network link is disconnected. It seems that the Ethernet is dead
Win_88
Specialist
@djdreamo
If you're certain it's not a configuration issue, it may be worth it to reset to factory settings. You may want to disable any VPN/TOR connections too before concluding it's a dead Ethernet port.
Win_88
djdreamo
I did a reset to factory settings but didn't helped.
Anyway the TV is under warranty and have been sent to Sony Service Center
