Netflix Problems
dan_88
Netflix Problems
Hello!
I've posted a couple of times before and everyones always been able to help, so I was wondering if you could help me with my latest problem!
I cant access Netflix! Thats the jist of it. I can access it on all my other devices, it just doesn't open on my TV (KD-49X8305C). I get an error message as follows:
"Error
Sorry, we could not reach the Netflix service. Please check Network Settings to connect to an available network and use Netflix (-100)."
I *dont think* this is Marshmallow related as I've searched the forum and not found anything. I also used Netflix on MM successfully a couple of times before the current issue appeared.
 I can use YouTube, iPlayer, Kodi, all fine, connecting to the internet fine, no issues. So im pretty stumped.
Obviously would like to avoid a factory reset!
I have gone into Settings and cleared the cache and data, restarted the app, restarted the TV, nothing changed.
Any ideas? Thanks in advance!
1 ACCEPTED SOLUTION
Not applicable
Hi there
Have you tried just simply rebooting the TV - Press and hold the power button on the TVs remote control for more than 6 seconds and a message will appear on the screen saying TV will restart.
It could also be an issue with Netflix servers?
At this moment, I have a similar issue with Amazon Video.  But other apps work, so... Assume Amazon issue.
Edit: See this article:
https://sony-paa-pa-en-web--paa.custhelp.com/app/answers/detail/a_id/144371/
4 REPLIES 4
Not applicable
Hi there
dan_88
@Quinnicus wrote:
Hi there
Quinnicus,
Your a legend! Somehow, even though I've restarted numerous times.... tonight, it worked! Thanks for your help!
profile.country.US.title
thekoniors
I have had my KD-55x900f since november 2018 netflix will work for a couple of days then I get the N and a spinning circle under it no error message I let it run for 15 to 20 minutes then hit the app button I have tried going back to factory settings uplugging tv letting it sit for a minute reloading netflix app, all work for a day or two but if you let it go into standby netflix will not work. amazon video works great on the tv so use that primarily. so sony is there a solution.
TobiasRieper315
Please see here:
https://community.sony.co.uk/t5/android-tv/netflix-not-loading-properly-spinning-icon/m-p/2566093#M3...
There has been a software TV update only yesterday/last night.  It took about 10-15 mins.
Hopefully, you will have this update aswell and apparently Netflix now works.
I have yet to test Netflix myself but will do so this evening ...
