Jim_Smith
RS 232 Control
Hello All.
Can anyone tell me any detials of the serial control port on the KDL-65W855C. The connector is on 3.5 mm  minijack on the back panel of the tv.  I can't find any information on the pinout, protocol or commands in the manual or so far on the web.  Has anyone used this port?  I had intended controlling this TV from an Extron control system, serially, but am now doubting whether this is possible.
2 ACCEPTED SOLUTIONS
Not applicable
Hi there
Can you please post a photo.  Reason being - in all the documents I have, there is NO RS232C control ports.
Jim_Smith
Hello again,
I know you don't need it but here's a photo anyway
Thanks again
undefined
4 REPLIES 4
Not applicable
Hi there
Jim_Smith
Hello, thanks for the reply.
Sorry, I can't semd a picture right now as I'm not in the workshop. However, my mistake, the correct tv id should be Sony Bravia FWL65W855C. The serial port is located to the left of the hdmi inputs if that helps.
Thanks for you time,
Have a good holiday
Not applicable
Hi there
The model number reflects Sonys Professional range.  And yes, i can confirm it does have an RS232 control port - so no need for a photo. :wink:
However unfortunately i do not have access to the documents required.
This may sound silly, but arnt the pins the standardised on a 9 pin connector?
Either way, my advice is to contact Sonys professional helpline and support.  Contact details:
http://www.sony.co.uk/pro/article/support-contact-us-for-support
Have a good holiday yourself (assuming your not working)
Jim_Smith
Hello again,
Thanks again
undefined
