I'm able to connect with my A8 TV after activating the WIFI Direct, the TV confirms my laptop is registered. However my laptop is still trying to connect , then says it couldn't connect after about 30 secs - see attached screenshot. Hence unable to extend or make my TV a second monitor.
Anyone know if they have similar issue and is there a fix around?
Belfiore attempting the connection did you put your tv in screen mirroring waiting?
Ps even if AFAIK miracast is not supported anymore in newer tv since last year. Only casting.
Yes i access the Wifi Direct or Screen mirroring setting to activate, so then it appears on my laptop (Win 10) under Connect. It confirms connection on the TV but my laptop then does - as per screenshot. Are you saying that these newer Sony TVs dont support the ability to become a 2nd monitor over WIFI? My last TV could do this,
i have used Chromecast, it does project my desktop only, not extend it. I guess this is a quick solution for use of additional screen over wifi. looks like need to plug it like in the office. thanks
