XF9005 ARC only works for PCM output
AdiThorny
I have a XF9005 with sound going to aa Yamaha R-XV681 Receiver via ARC.  The audio system only receives a signal from the tv when the audio output is set to PCM whereas I should be able to get a better sound signal than that.
Anyone had a similar problem?  Any ideas.
Thanks
1 REPLY 1
Win_88
Specialist
Hi
Which sources have you tried? What audio formats have you tried playing on the TV while testing other options than PCM?
Have you updated the TV: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xe80xx_x80xxe_xe83xx-series/kd-49xe8005/d...
Win_88
