proximity sensor issue on Xperia C
Ptandon
screen would not dispay after call is dialled. Re installed phone software, tested it with sony diagnotics, worked in 1 out of 4 or 5 instances I ran the test.
Any solutions?
58 REPLIES 58
Uliwooly
Is there anything near or on the proximity sensor? protective case, or protective film or even grim?
You can test it
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
Ptandon
Yes this is done.. There is nothing around it.. I downloaded this app also called proximity sensor finder from Google Play Store. It also showed the same results. Once an object is passed in Front of the proximity sensor..it detects.. But when the object is removed it doesn't....
Uliwooly
It might be a hardware issue. you could repair your phone with SUS or PCC but if that doesn't work then
http://www.sonymobile.com/global-en/support/contact-us/
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
sanjeet_sharma_
I brought xperia C 2 days ago and facing same issue.. Can anybody help us please
Uliwooly
@sanjeet
You don't have to create multiple threads, one is more than enough
Ptandon
Looks like a hardware issue to me as well. I had taken it to the service center who formats, reinstalls the os & gives it back. Works for  few calls & then is back to normal. The company is not yet ready to accept the issue as a hardware one. Slightly_frowning_Face
Only option I see today is to use a flipcase all the time & making sure that not even a fingerprint comes nearr the sensor. This is an un relasitic solution for a phone in this premium segment.
surtitanuj
Dear All,
I don't know whether this solved the problem or not, But even I am facing the same problem. I bought the phone last week and also put a scratch a guard on it.
When I am dialing a phone and put it on MY ear display automatically turns off but when I want to end the call it never turns on nor power button works.
Kindly advise whether I should remove this scratch guard to fix this issue or not or is their any other solution for this. I am having 30 days replacement gurantee with the online portal from where I bought this.
Thanks In Advance.
chetanrK
i bought xperia C 2 day ago...its proximity sensor is not working.....as soon as i make a call its screen goes off but dont restores to normal state even phone is not near to ears......is it hardware problem or any settings issue?
daraamir
guys i was also facing same problem but i removed the cover and then put the phone back in cover after that i press a little bit on both sensors to fit cover and after that swiped on sensor two,three times with a press..alhamdulillaha it worked..
