what is developer option near about phone in setting and how to use it
sagar1487
What is developer option near about phone in setting and how to use it?
What are advantages and disadvantages of using developers option?
Please reply...
1 ACCEPTED SOLUTION
sagar1487
How can I disable this option?
I don't want to see this option as like previous.... It was not there before this. I want like previous... what should I do?
14 REPLIES 14
profile.country.RO.title
_alexdon_
Developer options are,as the name suggests,some settings from where devs or people that know what they are doing can check some of the device's settings.I suggest you do not enable them and change settings if you have no idea about what you are doing.To enable it,settings-about phone-tap several times on build number.
alexdon
sagar1487
_alexdon_
To disable them,settings-apps-all-scroll down to settings app,clear data.
alexdon
sagar1487
I tried but not found... please tell me proper step by step...
_alexdon_
Settings - Apps - swipe left to reach All - scroll down until you find Settings application,tap on it and tap on clear data button.
alexdon
sagar1487
I found it but "CLEAR DATA" button is inactive..
_alexdon_
Are you sure developer options are enabled?
alexdon
sagar1487
I can enter in developer option... in that on-off option also there...
But as per your previous reply "CLEAR DATA" button is inactive...
I want to remove developer option in setting...
_alexdon_
I believe in 4.1.2 the option cannot be removed,you can only turn it ON/OFF.
alexdon
