DCR VX2100E ND switch Jammed
Exile69
My son recently purchased a 2nd hand VX2100E and is having a lot of fun with it. However, when first using it he noticed that the ND filter switch was a bit ‘sticky’ (didn’t operate smoothly) but now it has jammed completely. Luckily it has jammed in the ‘OFF’ position and the camera otherwise is operating normally but in the long run he would like to be able to use the ND filter so I was wondering if there was an easy fix to repair this or will it need to be sent to a professional camera repair specialist?
2 REPLIES 2
Mick_D
Moderator
Hi @Exile69, welcome to the Community.
I'm not familiar with that exact model, but switch issues are usually an easy fix if you know what you're doing. Any competent AV repair place should be able to give you an opinion on it, at least.
You could always get it to an official Sony repair place; there's a location map here which hopefully lists a repairer near you.
Mick
Exile69
Thanks for the help.
