HX400v
Please can you suggest a way to set up the HX400v so that it transfers photos wirelessly to my wife's macbook Air? I bought a wifi sd adapter but still cannot connect the Camera. Play memories software will not install on Macbook Air running Big Sur OS. I cannot follow the instruction using Play Memories. Any help please? Mike Many thanks
Edited[personal details removed]
Did you try this? One never can tell.
The camera itself should be compatible but what does it bring if the software isn't.
As a matter of fact this page confirms the incompatibility.
Hi there - why not use the SD card only?
Remove from the camera and insert into the laptop?
Hey,
As @BogheadBen said, I'd recommend using a direct transfer with your SD card, or through a card reader. Since your current IOS isn't supported.
Cheers,
