phone wont turn on , blinking red light and ive had it no more tha 3 weeks,HELP!
Hi @Jacob8692,
Welcome to the community. I am sorry to hear about this.
Can you please try holding the power button and the volume up button at the same time and see if it vibrates? If it does, keep holding until it vibrates 3 times.
i have had my sony experia e5 since feb this year and now for the second time i have had the same issue, both time the phone had plenty of charge, turned it off and when i went to switch it back on it wouldnt. i tried all things that i read about but none worked
i left the phone alone for a week or so then i manged to get it charging again, i know the charging cable was fine as i use it for charging other things
it is annoying as the phone is only 2 months old, after hearing i am not the only person with this problem it seems it is more a fault with the phone then anything else
im sure im going to be having same problem with this and it is about same as yours new but unyil i let battery die i wont know im atm thinking it power on
