Haggis1992
profile.country.en_GB.title
bettyhaggart
Haggis1992
My reader's screen has frozen halfway down; upper half is perfect but lower half appears as black horizontal lines on a plain white background.  It happened once before, but it corrected itself eventually.  However, no luck this time. I have Model 300. Can anyone help?
Haggis1992
Tags (1)
1 ACCEPTED SOLUTION
specialist-convergence
Hi, if one half of the screen is acting completely differently to the other, I would say it has a faulty/damaged screen, and would require service or replacing
4 REPLIES 4
carpetmojo
Hi Haggis - first try ab reset, hard or soft if the manual gives a choice - on a hard reset you will probably lose your library, be aware of that...
If that/those don't help, contact Sony Support, as it may be a sub-strata problem.
How old is it - and have you jumped up and down on it at all ??
bettyhaggart
Hi, thanks for your help;  however, tried soft reset and turning a few pages forward and a few back, but but the problem is still there.   It does seem to right itself from time to time for no reason I can see, but after a time reverts back to bottom half of screen freezing with a blank screen or various thicknesses of lines running horizontally across bottom half of screen.   Device is less than a year old and I have not knocked it or "treated it badly"!  Anyway thanks for your input.
Haggis
bettyhaggart
Hi, thanks for your advice regarding my reader.  Have taken your advice and sent device to Sony to have a look at.  Now awaiting their answer and solution.
Thanks again.
Haggis 1992
