Bluetooth connection
Truppster
I have a Sony MHC-V41D audio system which I’ve had for a couple of years. I had my iPhone connected via Bluetooth but now I can’t connect any phone via Bluetooth. I’ve tried 2 different iPhone 12s and a Samsung. None of them see the audio system. Is it possible that the Bluetooth has packed up? The pairing light still flashes.
1 ACCEPTED SOLUTION
Truppster
Thanks for this, it’s sorted now. I had to do a system reset.
2 REPLIES 2
IamNic
Hello @Truppster,
you need to activate the "pairing" mode - of the light flashes slowly, it is trying to connect to a previously paired device. To pair a new device, you will have to hold down the bluetooth button until the speaker tells you it is in pairing mode.
screenshot from the manual.screenshot from the manual.
- Nic
Truppster
