Sound Problems
pehugge61
Sound Problems
Hi  I have an Sony Bravia KDL-37W5500 tv connected to a Humax Foxsat HDR
and a Sony HT-XT1 Home Theatre System. (Not connected to internet)
I can change the sound from the TV to the HT-XT1 by using the TV Remote,
and pressing the blue Home button ,going across to Settings, down to Audio Settings
then Speaker, and changing from TV to Audio System
If I leave it on TV and switch on the HT-X1 I get sounds from both
My Question : Is there a simple way of changing the Sound Outputs,
  without going through the process shown above ?
1 ACCEPTED SOLUTION
Win_88
Specialist
If you want to change the output manually, the steps you mentioned are the only way to do it.
4 REPLIES 4
Please try the following:
1st turn on your soundbar
2nd turn on your TV
This should play the sound from the soundbar only.
Win_88
Specialist
pehugge61
Hi  I’m afraid this did not work,still got the sound from TV and Sound Bar together, but out
of sync .I can mute the tv by the button on the  Sony remote therefore getting just the Sound Bar.
Thanks for your assistance made me think 😅
pehugge61
Yes ,Think you are correct bit of a pain though 😤
Thanks for your help
