DAV DZ860W
DAV DZ860W
Hi, i have the dav-dz860w sony 5.1 and i have a problem as it has no input for HD is there a solution to this problem?
1 ACCEPTED SOLUTION
Not applicable
Hi there
I have had a look at the specifications of your DVD Home Theatre System.  I can see that it has a HDMI OUT, and SCART OUT.  Unfortunately there is not a HDMI IN for your system.  There are two inputs for audio which may be of use.  The DIGITAL IN has Coaxial and Optical inputs.  So if you have another device, try connecting an optical cable to the DVD system.
See page 22 and 23 of the manual : HERE
Cheers.
1 REPLY 1
Not applicable
Hi there
Cheers.
