Problem connecting S1100 to the internet using ethernet cable
choisty
i have just purchased the blue ray player bdp
-S1100  i am trying to connect it to the internet with a ethernet cable as per instructions but it keeps coming up physical connection ok  internet access failed any body got any suggestions i would be gratefull for any help as i am not very I T orientated  thank you    TOMMY
1 ACCEPTED SOLUTION
Not applicable
Hi there
Select Setup from the home menu and goto Easy Network Settings and follow the on screen instruction.  I cant remember what they are, but choose auto for everything.  If it mentions DHCP choose that.
Cheers.
1 REPLY 1
Not applicable
Hi there
Cheers.
