I have just bought a KDL32X520 - BARGAIN.
However on some programmes there is an irritating voice over.
I have accessed digital set up > audio set up .> audio description but this is turned to off !! This problem occurs when I am watching virgin via HDMI 1. Any answers ?? thanks
Hi, philsas
You need to switch off the audio description on your Virgin box - Home - Settings - Change Display and Audio Settings - Audio Description when available
However, be warned that when I do this there is a horrible buzzing on my Bravia, which is why I have come onto the Forum! I am hoping someone will tell me how to get rid of this buzzing which only occurs on my Bravia and not on another TV I used to test the setting!
Best wishes
Briantwc
how odd, if audio description is set to off then it should be, you could try doing a factory re set to clear any glitches in the system, re check audio description is still set to off and try again.
Hi, philsas
Best wishes
Briantwc
^^^ what he said ^^^, cant believe i missed that, having a TiVo box myself, however who turned audio description on in the first place as its normally set to off.
