Difference between Brightness and Backlight Level
The picture menu on my 40EX503 has seperate controls for brightness and backlight level. Is there a right/wrong way to use these settings to bring the overall picture brightness up a touch?
Secondly, the factory default setting for contrast is 100% - is that normal?
Thanks
Hello,
I found the following on internet which may help
"Brightness - changes the colours of the pixels on the LCD screen. For example if you turn the Brightness up high, black pixels will change into light grey pixels.
Backlight - is the intensity of the fluorescent lamp behind the screen that makes the picture more intense. This should be set low to get realistic blacks."
The default setting for contrast 100% is in vivid mode (I think).
I think "Standard" settings look much better (my preference), however they can be adjusted to suit.
Hope this helps.
