KD55XE7002BU won't turn on until turned off/on at the wall
horsemanuk
Hi, can anyone help with a minor(?) issue with my KD55XE7002BU TV? It works absolutely fine but sometimes it won't turn on by the remote or the button on the side. I have to turn the TV off and on again at the wall, then it starts responding again. It's slightly annoying, although I'm more concerned that it might be a problem that will get worse at the TV gets older.
5 REPLIES 5
horsemanuk
I should have mentioned that the TV in only 12 days old. It's happened three times so far.
horsemanuk
Mick_D
Moderator
Hello horseman, welcome to the Sony Community :slight_smile:
Unless someone here has experienced the same thing and can shed some light on the issue, I would recommend you contact Sony Support about this and see what they recommend.
Best wishes
Mick
horsemanuk
Hi Mick,
Thanks for your response. I contacted Sony Support a few days ago and I got the following back, which feels like a very generic "reboot, re-install" response. I've done what it says and I'll see if the problem goes away.
Thank you for contacting Sony support regarding your KD-55XE7002.
We are sorry to learn the TV freezes and stops responding to the remote control.
Regarding your query, please follow the below troubleshooting steps to help rectify the issue:
1- Unplug the TV from the mains for 60 seconds and plug it back in.
2- Update the software of your TV to the latest version via the below link:
https://www.sony.co.uk/electronics/support/lcd-tvs-xe70xx_x70xxe_x72xe-series/kd-55xe7002/downloads/...
3- Factory reset the TV to the default settings via the below steps:
First please disconnected all HDMI connected devices.
- Please press on the home button on your remote control.
- Scroll right to settings(the brief case logo).
- Scroll down to general setup.
- Scroll down to factory settings.
horsemanuk
The above did not work. A day after I followed all the advice we were watching Netflix and I pressed the Home button. The screen went blank and the TV became unresponsive. The light flashed at the bottom of the screen when the remote was pressed but nothing happened. I had to once again turn it off and on again at the wall. 😞
