I had this all set up and was using it about 4 hours ago and now I can't get it to work. For some reason it kept connecting to an erronous IP address outside of my network and the only way to get rid of it was to reset the box which I did. Now I cannot get it to connect to my wireless. When I do a scan of wireless routers none of them show up and there are about 4 around that usually show including mine. What else should I try to get this working again? I've already tried manually adding all my gateway, ip, and dns with no luck.
Hi
If you can connect it via Ethernet, do this first of all to update the firmware. Then switch off the router and N200 for a few minutes which will force everything to re-scan which should hopefully then reveal your router. The device is pretty robust so this should hopefully just be a temporary wobble.
Hope this helps
