WiFi Deivice is not accessible KDL-43W750E
rafinkarki
I am trying to access wireless internet connection in my Sony Bravia TV but it says my default built-in Wifi is OFF. Try to setup wireless network but SSID never discovered. I did Factory Rest multiple times but the issue still persists.
22 REPLIES 22
Tenneen9000
Hi rafinkarki,
Can you explain more? Does the TV fail to discover the SSID of your own WiFi network only or all the networks in your area? If it's just your network, can you tell us what happens when you try connecting to a mobile hotspot?
Cheers,
Tenneen9000
rafinkarki
Its not discovering any of the network. Not mobile hotspot.and not from router too.Wireless device on tv is offWireless device on tv is off
No network discoverdNo network discoverd
profile.country.IT.title
Marino.Manolo
Wireless Device on TV: Off
That's the problem, you need to turn on Wi-Fi (On)
Manolo
rafinkarki
Now where do i do that exactly? I see no settings? Couldnot find the way to do that.
Marino.Manolo
Settings > System Settings > Set-up > Built-in Wi-Fi: Turns the built-in wireless LAN [On] or [Off].
Manolo
rafinkarki
I did that earlier but no luck.15498056336531324918561.jpgafter that i checked my network status.but still its off.
Marino.Manolo
Ok, try to disable Wi-Fi Direct...
Manolo
rafinkarki
Yes i did that too and checked network status.but still same issue
rafinkarki
Any further steps with the solution?
