I bought my sony FS about a week ago (fs215s), and I've been noticing what appears to be backlight bleeding.
When viewing a black screen in windows (e.g. screensaver) I get light which appears to be coming from the bottom of the display, and also some light at the top.
I've noticed that my taskbar is extremely bright in windows, and the start menu looks 'washed out'.
The only way I can fix this is in the nvidia control panel, by changing the colour correction and turning the brightness down slightly. However I still get the light on black screens from the bottom etc.
Is this normal? Can I get this fixed by sony? What could be causing this problem?
Thanks. Posted a link to a picture of the screen below.
http://www.unknownbeings.com/tom/DSC03191.JPGhttp://www.unknownbeings.com/tom/DSC03191.JPG
got my laptop 3days ago. that backlight bleed thing is normal, i have a brighter bulb at the bottom as well on my laptop although sony claim their lighting is even across the screen it isnt. all the laptops of this series have the samething, i dont think it can be fixed.
Ugh
I don't know what to think any more, mine seems to be bright at the top and bottom, but leaves a dark band in the middle. Wierd but only noticable on a black screen.
I agree with TT, get all dodgy screens repaired. The chances are the entire screen will get replaced.
If it's only 3 days old take it back to the retailer and demand a swap
the exact same laptops on display were all the same, the lower light is brighter than the upper light, the one they sold me was brand new in a box, if i get it replaced i will just end up with another laptop with the same problem, to be honest the bulb isnt that much of a problem only on a completely dark screen you can notice it. actually i think his bottom light is a bit more intense than mine i'll take a pic and we can compare, then he would get more of an idea how messed his laptop is. or how messed up mine may be.
follow the link to the pic above. its
http://www.thenokiazone.com/vaio.JPG my backlight isnt actually as bad, no light at the top, with alittle at the bottom. copy and paste the link into browser, dont click it, wont work that way if you do for some reason.
I got a reply from sony this morning -
"it would appear that this behaviour is normal and is more visible on this dark background.
This is due to the backlight shining through. Within specification. "
But I know its not correct, I've seen numerous models in store without this problem. What can I do?
I don't know what to tell you. I know mine is nothing like as bad, nor is the bottom light worse than the top. They are completely even.
Its lighter than it should be
I agree with TR, they'd need to do a physical test to see this for real
