Hello everybody,
i've bought an FS 215M, great laptop.
I have a problem with the display, the display of police is not very good the police are not precis, almost blur...
here a screen shot of the problem, i hope you can help me.
http://img306.imageshack.us/my.php?image=probleme13gm.jpg and here http://img90.imageshack.us/my.php?image=untitled18pq.jpg
thanks by advance
Pierre
france
not sure here, really
The Problem is. That I can't see your problem if you have a display fault.
A screen shot is useless. Because it shows your screen, but your problems with the TFT.
If you have a digital camera, then take a picture with it of your TFT screen with the problem.
I am baffled by this
Try a system restore to a time before the problem started
thanks everyboyd for your answers.
I will format my computer....
i will send you a message after the format ...
thanks again
Pierre from france
Pierre, what you might want to try is downloading the official nVidia Detonator drivers (WHQL approved), instead of using Microsoft drivers.
Like the other guy said; you need to take a photo of your screen, not a screenshot, as it appears fine on all our screens (touch wood lol)
Also, perhaps the problem is all the weird software you have installed, just try running a standard freshly formatted computer for a while - use the disc the machine came with.
Failing that its probably an LCD cable problem, in this case you should contact Sony with eSupport to seek a repair or replacement.
Good luck, let us know how it turns out.
Hi Pierre
I'm facing exactly the same Problem with my Z1RMP! Have you found a solution?
On my machine sometime it helps by bressing a litte bit right obove the touchpad!
Regards and thanks for your answer
