Besoin d'un renseignement sur "SWAP" insuffisant !
Need some suggestions about not enough "swap" !
Thanks
mon ami
je ne parlez francaise...
ok .. you can tray with partition magic 8.... you can just delete swap partition...:smileygrin:
Bonjour Doru et bienvenue a la Forum.
J'espere que vous passez de bon temps ici!:smileygrin:
Oui, bienvenue au forum
Mais fassiez attention de Jumpsuit. Il aime de jeunes chevres.
Et cheeseburgers.
Welcome XAV38.
I cannot explain this in French so here goes in English:
Go to Control Panel and double click on System. In the next window select the Advanced tab, under Performance (visual effects¿) click Settings. In the next window select the Advanced tab and in the Virtual Memory box click Change. You can then alter the paging file (swap file) size.
I hope that all this makes sense.
I will explain it in French Rich
Allez dans le paneau des controlles
double click dur Systeme
dans le window prochain selectionez le tab avancee
desous Performance (effecs viseaux, clickez sur settings
dans le window prochain clickez sur advancees
La change le memoire virtuele
Thanks Kee-Lo.
