Please, show me the site with firmware for my Pioneer DVR-K16M.
I can't find it in your link site.
I have just purchased a Vaio VGN-FE28B. After about a week the DVD drive no longer responds and is not visible on My Computer.
Under Device Manager there is a Device Status: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
I have tried restoring back to the date I purchased the machine but the restore fails.
The DVD is a DW-G520A.
I cannot use the restore DVDs that I created as the DVD is not responding.
Have searched on the support site for the code and driver updates but to no avail.
Any suggestions???
Hi mops31 and welcome to the form.
This thread may be of help to you. Make sure that you make a backup of your registry before making any changes.
I also though my pioneer was coming to an end, but after some testing with different medias I realised that....
My Pioneer DVR-K16M writes 1X speed when I use 16x speed DVD-R otherwise with 8X speed it works normally.
This should be fixed with an upgrade since I previously had these problems with other drives manufactured before certain media is in the market.
I called SONY no update and PIONEER is not liable since the drive although being a pioneer is not sold by them but by sony. So Sony is to fix this problem, which apperantly THEY STILL DIDN'T.
VGN FE11H
Approximately a month ago I purchased a Vaio - VGN N11S, but like a couple of other responses so far on this thread, after a couple of weeks I've stared to have problems with the CD/DVD R drive. As I'm not writing this from my notebook I'm afraid I can't mention what the drive is.
I backed up my laptop before I started having the problems and I've even downloaded the updates. After logging a call to the support team, I'm still finding I'm having problems.
Is this a problem through-out Sony?
As a consumer in the UK I'm entitled to a refund or new replacement of my notebook surely.
I have a 3 month old VGN-TX3XP/B and I can't read DVD's anymore from AV mode and playing DVD's through Window is getting to be a problem too. Would be glad to hear if owner of same model have experienced the same issues, I am sending the unit for repair.
Hello,
I'm having huge problems with Nero 7 and my FE11S. It was working fine until recently. It has now started to blurp out the following error, when I try to burn:
Unable to recover TOC
My drive is a MATSHITA DVD-RAM UJ-841S, with DMA = On.
EDIT: I have no reading problems on the drive, everything is fine in that department.
I only use Verbatim DVD-R 16X Media. I have tried re-installing Nero, turning the IMAPI CD-Burning service on/off and finally updating the firmware of my burner, still no luck.
Got any ideas? It is kinda getting on my nerves, since I have a lot of data I need to back-up.
Thank you in advance.
since several months I have a problem with my CD-DVD driver, it can't any more to record a DVD, when I enter an empty it tries to find it and on the end it ejects it afer 2 minutes.
Also CD recording has got some strange very high sound. Some CDs were nonusable.
Also, DVDs created earlier are very hard to read.
It is SONY DVD RW DW-D56A.
I use VGN-FS195VP.
I tried to reainstall the system.
I updated the driver from Vaios homepage.
I have tried several types of DVDs.
Any idea?
Hi skinkendk and welcome to Club Vaio.
