IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
Thalamus.
Champion
Hi Obbie,
You may find this KB314060 of interest..
obbie
Thanks Thalamus - Ihave followed these instructions & my drive is now available. Any idea what causes this error to ocur, as the driver is obviously not corrupted as it now works OK
cheers
obbie
:slight_smile:
Thalamus.
Champion
:cool: You're welcome obbie.. :slight_smile:
The reason the problem occurred is usually due to a burning program being removed but I guess it could be any number of reasons.. :thinking:
quantumfly
I had no end of problems with the Pioneer DVR-K12D drive on my PCG-K215B. It worked for a good couple of years on and off then almost totally died. The only thing it could read was CD-Rs and pre-recorded DVDs. I even had to make my own recovery CDs from the recovery DVD 'cos it couldn't read the latter!
Anyhow I got bored of Sony Support, who told me recover the system even though I'd told them that I'd already done so (do they listen?), and I fixed it myself. I bought a reconditioned drive for about £100 from an online store in the States. Bought a service manual from eBay and some micro screwdrivers from Maplins. It was a bit scary taking my baby apart, but I went slow, noted where all the screws came from and made sure I was well grounded to the unit. As a bonus I got to clean out two years worth of dust which made it run 10 times better (and quieter).
If anyone wants any advice on doing it just ask.
fravannini
My error,in a vaio VGN-N21 S/w, is:Impossible to load the driver for this hardware. The driver may be damaged or absent. (Code 39).I tried to install the new firmware but it say no device found or no administrator right to process.
Thank you for your help
Thalamus.
Champion
Hi fravannini
Welcome to Club Vaio.. :slight_smile:
Have a look at KB314060 for a solution to resolve the problem..
Venta3
Hello, I have a brand new FE41M and the DVD/CD player doesn't read any of my purchased software programs, except my Microsoft office. I was thinking it could perhaps be related to Windows Vista. As my computer is under garantie, should I send it back? What do you think?
Venta3
mike_stuart
Anyway... enough of a rant! If anyone can help, I will be extremely grateful.
Hi Mike,
If you look back through this thread you will find a simple solution to a Code 39 error.
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=39917
:wink:
It's been a while since I last posted but the method detailed on that link (using REGEDIT) didn't work, so I'm going to have a look at KB314060 for a solution, if not I'll have to phone up Sony Support again and get it sent off to get properly looked at. Warranty expires in October so I need to start thinking about getting it sorted properly.
caloira
Hi, I have a similar problem to Venta´s: I´ve a new VGN-FE41M and my DVD/CD-driver doesn´t work. It doesn´t neither read software nor audio-CDs. It´s not listed under "Computer". The Device-Manager shows a triangle with "!" and Error Code 39 concerning the DVD/CD-driver. Under Vaio Support I couln´t find any solution for my problem. Can anybody help?
rich912
Contributor
Hi caloira and welcome to the forum.
Have you followed Thalamus's link above?
In essence this refers to CD error codes 19, 31, 32, 37 or 39
If Device Manager is reporting an error code of 19, 31, 32, 37 or 39 then it is probably a registry problem. I recommend that you backup your registry before proceeding, have a look here if you are unfamiliar with this.
Then:
1.Click Start > Run and type: REGEDIT , and hit enter.
2. Navigate to - HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and locate UpperFilters, (if available) right click on this and select Delete and then OK.
3. Under the same Registry Key locate LowerFilters, (if available) right click on this and select Delete and then OK.
4. Quit Registry Editor and re-boot the computer, new registry values will be created.
After you remove the Upperfilters value and the Lowerfilters value, you may possibly need to re-install your burning software – but not necessarily.
EDIT: Just realized that your machine is running under Vista. You therefore need to type 'Regedit' into the search area after clicking the Start pebble...
Go n-éirí an bóthar leat
