IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
Blencogo
Hi euripyd.
The Sony DW-D56A has always been a useless drive. I'm sure you have read this MONSTER THREAD.
This drive usually has to be replaced but look at the last few posts in the thread - MX Motion has had success in fixing his drive by downloading a firmware update from the drive's original manufacturers (Lite-On).
:wink:
skinkendk
Thank you for the prompt feedback.
The DVD+R could maybe work, but since it has worked fine with quite a few DVD-R, it would be a bit strange for it to change it's mind, all of the sudden. I will, however, try to burn something as old school as a cd-rom tomorrow and see if that works.
The MS/DRM angle actually makes a lot of sense to me (remembering that our Windows' might be getting prepared for the Zune software, which I understand is to be fairly DRM-heavy). I might just need to investigate what I have in fact downloaded and installed from MS lately, to figure out if anything has lurked past my critical eye. The stuff I want to burn is not DRM protected, as it is my own produce, but DRM might still be the issue on this one.
I shall report back when I have tried to burn a cd, my good sir.
Thank you
euripyd
Thank you Blencogo
I will try it, and come back if I manage to fix it...
I am so sad, I believed that it wouldn't happen to SONY....
Blencogo
Goos Luck euripyd!!!!!!!!!!!!!!!!!!!!
:thinking:
MXMotion
Hi All,
I am totally convinced this whole farce is down to non compatible firmware updates..
If anybody needs ANY help with this I am available to help.
BTW if you do decide to try a 3rd party firmware update your going to loose your warrenty so tread carefully
Peace out
Motion
euripyd
i had no success.... :slight_frown:
I have reinstalled the 1st version (from the link that MX Motion has provided at an another topic).
It didn't work.
Than no2.
and again no 1.
Before I had version no 3.
I have noticed that after I have upgraded to FW no 3 my computer goes on very slowly even I downgraded to FW 1 or 2 (I upgraded also BIOS, and Nvidia card - maybe thats why it goes slowly on from "Welcome" screeen).
I have purchased the notebook in May 2005, in Sweden. I have no warranty any more.
Any idea?
MX Motion?
MXMotion
everytime I mess about with firmware etc for a little while after my start up is slow too, something maybe not to be too worried about, I've personally never flashed my BIOS as I felt this was a firmware issue with the drive itself and not the computer at fault so I cant really comment on that
Ok this is what I would personally do..
(1) Restore the PC to "factory spec"
(2) Allow the pc's applications to bed in, such as the Vaio Launcher, Norton AV etc so that no other applications are wanting to complete their install/recovery
(3) Another thing I did was to download a RPC2 removal program LtnRPC which is available for download at most locations, now tread carefully as I would never suggest you loose your warrenty as that is what you will do if you use 3rd party software to mess with your exsisting drive firmware. I have used this completely as a work around in order to get MY laptop working as it should.... and then i re enabled the region settings again shortly afterwards
(4) The install the PFS-1 - not forgetting to disable all other programs as you would if you were using the Sony update.
(5) Try PFS-1, It personally did not work for me but try it all the same... attempt a burn or something.
(6) Try PFS-2, this is where my drive roared back into operational condition... a great day indeed.
Get back to me if you need
Motion
MXMotion
Ok firstly I would take the laptop back to factory spec by using the recovery discs in the fashion explained already.
then I would make sure that ALL the applications that come with the laptop pre-installed are running ok, (Vaio Launcher etc), and have the full recovery process has been completed. Restart the laptop after this has been done.
Now I would begin the process of using the 3rd party firmware updates... Im assuming that you have unpacked them as they come as a rar file.
Start with PFS-1, this totally failed for me, but maybe try a burn at this stage anyway.
Then try PFS-2, at this stage my optical drive burnt like a forrest fire, like a whippet I tells you
Also try as mentioned to clean the drive with an appropiate cleaner disc..
Hope this helps
Motion
MXMotion
Ok this is what I would do personally IF what Blencogo has suggested and it has not worked
Also before I mention what I would do
again this will void a warrenty and you do so at your own risk
(1)Download and unpack from the .rar file the three stock.exe's for the drive. The reason for unpacking them now is that when your pc is returned to factory configuration you cannot unpack the rar.
http://codeguys.rpc1.org/firmwares/dvdrw_slimtype/stock/Sony.D56A.PFS1-PFS2-PFS3.stock.rar
Also find and download a RPC2 removal program LtnRPC. Unpack if neccesary.
And then store the files on a usb memory or external HDD or disc. If you are burning to disc you might want to fill it up with any pictures or other media you want to keep.
(2) Perform a full C:\ Drive System Recovery using your Recovery Discs. Make sure you back up all your Data as the contents of C:\ will be lost.
(3) Allow all the pre installed software that comes with the laptop to iinstall itself correctly, Vaio Launcher, Norton IS etc so that nothing else wants to install itself.
(4) Restart the PC.
(5) Place the saved files from section (1) on to your desktop. At this point you might want to try the RPC removal tool LtnRPC. Sometimes it says that it has not done anything but upon checking the properties of the optical drive its deffo removed the RPC-2. Try and burn at this point.. sometimes I had luck with this alone. If still not working properly proceed :
(6) Re-enable the region settings for the drive using the Ltn-RPC. Now once upon a time there was an "issue" with Sony placing a type of encryption on their discs XCP i think it was called.
Ages ago I came across this issue with my laptop, XCP had reduced my drive to a similar state so I decided try this as well after I tried the LtnRPC program, I was desparate at this moment.. i really wanted to fix my laptop:
http://cp.sonybmg.com/xcp/english/updates.html
Completely uninstall the XCP software and associated content protection files.
(7) Disable all the things you are meant to do as if you were following the instructions for a Sony Updates firmware installation. Disable the Anti-V, screensaver, hibernation etc.
(8) Flash the PFS-1 on to the drive and restart.
(9) Attempt a burn or something, this failed for me.
(10) Flash the PFS-2 on to the drive and attempt a burn.
Thats all I can suggest. If not then It looks like you may have to consider a replacement drive. may the force be with you.
Motion
gliss
I have a VGN FE 21M and my cd writer SONY DVD RW DW G520A burns DVDs only with 0,76 speed and CDs with 4-5. It also can be seen that in Nero the drive's buffer always fluctuates between 5 and 100%.
I have tried to reinstall it and to flash it, but the prog says that it cant find the device, but sony says thats normal if the current firmware is installed.
What can I do? Burning a four gig DVD takes !!!! two !!!!! hours.
I hope you can help me.
Thanks!!
