Hi walms - I think you are in luck!!!
A small Registry edit will fix your problem. Be careful and don't change anything else while you are in the Registry.
1.Click Start > Run and type REGEDIT and hit enter.
2. Navigate to –
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
and highlight it. Then locate UpperFilters in the right hand window, (if it exists) right click on this and select Delete and then OK.
3. Under the same Registry Key locate LowerFilters, (if it exists) right click on this and select Delete and then OK.
4. Quit Registry Editor and re-boot the computer, new registry values will be created that will hopefully cure the problem.
After you remove the Upperfilters value and the Lowerfilters value, you may possibly need to re-install your burning software – but not necessarily.
Welcome to Club Vaio and Good Luck !
Hi.Do you know if is there any update firmware for sony DW-u54a?
Thank you very much!!
Hey,
Thanks, that worked a treat! Do you know why it happend/happens???? Thanks a lot, i thought i may have to send it back!
cheers
Wow Wow Wow, it works!
Had to post to say that I've been metaphorically sitting on my Vaio for the last 18months with the DVDRW drive not recognising any discs I put in it, so hence not burning or playing anything....Had been in touch with online support half a dozen times, upgraded firmware, uninstalled drivers etc with no luck. I posted a drive relpacement question last week I was that desperate to get the damn thing working again. After reading all the posts in this thread I tried lens cleaning and freeing the moving bit in the dvd drawer, and bloody hell it's all working again. $2 (I now live in Aus) and 10 mins is all it took. I think Sony should advise people to do this on a regular basis! THANKYOU Brown Polar and Blencogo for your posts, you've solved my problem and saved me around $250. PS, I have nil techie exp, anyone can do it! :smileygrin:
Hi lovely_mummy,
Nice to hear you have got it sorted !!!!
You are now a DVD Drive 'Expert'
:smileygrin: :smileygrin: :smileygrin: :smileygrin:
Hi dogma43 and wecome to Club Vaio
When I look into the properties of the drive (in the device manager), it says: Code 41
Hi everyone......new to this forum as I have just purchased a laptop and having problems and need some help. I have a VGN-CIS/W and my dvd drive is missing when i started up. I have only made my recovery discs, updated any updates and had a quick look at what programs were installed. I'm also getting a message that updates are ready(windows auto) and even though I have installed and rebooted they keep coming back. I obviously cant use my recovery disc so I was hoping someone could give me some advice taking into account that I'm not great with computer terminology Or should I just demand my money back !!!!
hi everyone,
i have a vgn-fs115z model and i´ve started having problems with my cd/dvd device. it reads every cd or dv disc but refuses to burn any of them. now it seems that the drive doesn´t recognize any empty disc... i´ve tried the lens cleaner, but nothing changed. please, please help me, as i need my computer to work!!!
