Hi
Can anyone tell me the maximum upgradabilty the Sony PCV-RX201 desktop can take in terms of the following:
1) Max CPU (I currently have only P4 1.6mhz)
2) Max RAM and spec (I currently have only 256mb)
3) Max HDD (I currently have only 60gb)
4) Can this model support in nternal 2ndry HDD?
5) Can this model take a internal Sony Dual Layer DVD writer?
6) Can the current Geforce2 Ti 64mb VGA card be upgraded?
Any feedback anyone can give me will be much appreciated.
Many Thanks
Sat B
1. should upgrade to 3.4 without ht technology certain its uses 533fsb in this case then wont support hyper threading technology note: note: (may need bios upgraded))
2. ram max is Upgradeable to 1024 MB)
3. hard drive is ide hard drive so will take most ide harddrives
4.should'nt be a problem..
5. no reason why not check out www.ebuyer.co.uk for dual layer drives
6. yeah should be fine check if its pci or agp slot
regards chris
I'm not sure abou that CPU upgrade????
