Sony Vaio Screen Cleaning Help
waleed_wc
Has this ever happened to anyone, i sprayed a anti-static foam cleaner on my laptop screen to clean it, then after i wiped it of i realized that there was a bloch of liquid in the middle of the screen, dont you think that this is kind of rediculous, liquid in the middle of a screen without it seeping through from anywhere??
Any suggestions?????
1 REPLY 1
Twisted-Rizla
Unlucky:smileysad:
As you seem to have found out to your cost some Sony screens are porous.
If the spray is alchohol based there is a small chance that it will simply evaporate over time. However, the detergent element probably won't evaporate so it looks like it might be there for ever.
Leave the screen closed for a while in the hope that gravity works it out the way it went in.
