After 5 years of the sony vaio working great - things started to go wrong with it, and i decided that it was time to format the hard drive by using the system recovery disks that i created when i initially got the computer.
So after formatting the drive, and and using the second disk, application recovery, i was faced with the next message...
"Reboot and select propert boot device or insert boot media in selected boot device and press a key"
when i pressed a key the message reappeared, so i took out the disk and pressed the key - and the message reappeared, so inserted the system recovery disk again - and it came up with the system recovery utility again...
and came up with a pop up box saying
" the revocery partition is active
Eject the disk and click [cancel]
your computer is restarted from the recovery partition in the hard drive. If you want to use the disc, click ok"
then the whole thing begins again
I seem to be going round in circles.
how do i get back to using my dear old computer i love so much?
Any ideas people?? Please help me!
Try removing all the discs and reboot.
During reboot - when you see the first Vaio splashscreen - repeatedly tap F10
This should start the recovery utility from the hard drive recovery.
Select to Recover Drive C:
Follow this guide from Step 2.
