i have a sony vaio Pcv rs704 with a recurrent problem with sound everything works normally then sound disappears , every type of sound cd , music file , system sounds . If i turn up the volume from the keyboard I can hear speaker hiss , so the speakers are working , also Itunes won't play at all ie the any music files won't run ( even though no sound , the progress indicator for file playing doesn't move ) while this sound problem persists . I can usually fix the problem with a reboot at which point system sounds return as the computer goes into shutdown so I think it might be a software conflict ,though this fault has persisted after several system reinstallations
No problem.
Was it a DivX?
If so reinstall it, or better get v6
yeah! i downlaoded the version 6.0!
Its all better now!
nice smilie Kee lo!
I followed those instructions but could not see wmplayer.exe in task manager , however have downloaded Divx 6 and hope it makes a difference , Thanks for your help , incidentally if not windows media player , what else could be causing it ?
What program are you using when this happens?
