Unable to use Vaio Recovery Tool on my VGN-TX3HP as it says this software only works on a Vaio computer?????
Are you still using the original Sony Operating System?
Try resetting the BIOS defaults before trying again: -
To Reset BIOS defaults
You could also try the same as a. above but press F10 multiple times - this should start the Vaio Recovery direct from the Hard Disc Recovery Partition.
