Smaller WF-1000XM4 Earbud Size
chrisfw
I was just given a pair of WF-1000XM4 headphones. As I know from previous in-ear headphones, I have small ear canals, so I put the smallest earbuds provided onto the set.
As is the right headphone has trouble fitting into my right ear. It can feel a bit loose, but moreover the sound in that side is muffled. It only sounds clear and direct into my ear when I pull up the top of my earlobe. (which, obviously, is not viable to sustain.)
When I push it in to try and make sure it is in properly and can hear it clearer, it is uncomfortable, and the earbud stays in my head when i pull the headphones out.
Are there smaller earbuds that fit the WF-1000XM4s? Any help appreciated.
2 REPLIES 2
Bat_Rick
I have checked the manual and "S" size is the smallest, can you fit any silicon eartips on the unit?
chrisfw
thanks for reply - these are smallest I could find, do you have any examples you know of of silicon buds that would fit this model? as I can't seem to locate any! many thanks
