Application for the Original Case with Magnetic flip
Burnahead1
Hi
I bought SCR 56 STyle Cover Touch but I don't find the application to configuring the cover settings.
Note, the application is present in the applications installed but I can not find it in home application...
Thank you
1 ACCEPTED SOLUTION
Emil
Enthusiast
Hi @Burnahead,
To be able to access the app Style Cover you must first pair your SCR56, Style Cover Touch with your Xperia X Performance. This will enable the app Style Cover in your phone.
Let me know if this helps! Slightly_smiling_Face
9 REPLIES 9
profile.country.US.title
Qatrium
@Burnahead
I don't think there should be an application for the cover nor options to adjust. If you pair it using NFC then the magnetic sensor will just work as it should. At least that was the way it goes with my older Style cover on Z5 and X.
Qatrium
@Burnahead
Hmm that's something new for me. Did you try searching for the app name in the search bar of your app drawer?
Burnahead1
Yes I tried but nothing...
I suspect the cause is due account and transfer from my old phone apps
Qatrium
@Burnahead
Then try to remove the application then redo the pairing process:
- Go to Settings -> Apps -> Style cover -> Uninstall and restart your phone.
- Touch the NFC tags of your phone and cover again.
Emil
Enthusiast
Hi @Burnahead,
Burnahead1
@Emil wrote:
Hi @Burnahead,
Solved with pairing solution and it works! No instruction inside the package confused me. Actually, I could see NFC in the middle of the cover and intuit the procedure eheheh.
Thank you very much
Burnahead1
@Quester wrote:
@Burnahead
Hi there,
style cover App adjust light screen automatically when cover is closed.
Ty
Emil
Enthusiast
Glad to hear it is working now @Burnahead! Grinning_Face_with_smiling_Eyes
If there is anything else you are wondering about, let me know!
