Hello,
is it possible to use the Samsung Gear 360 Manager app with the Sony Xperia X compact phone, to control it with it?
@YoGem wrote:
Sorry, it does not. Samsung is using this bad policy of allowing to use some hardware with specific apps that work only on some Samsung phones
No, that has changed. I installed the .apk manually and I could connect it to my Xperia Z1 compact. I saw the photo on the gear 360 but than it freeze. I also couldn't control the cam with the smartphone, than it also freezed.
So I wanted to try it with the Xperia X compact. Before I buy it I wanted to check, if the app runs.
But now I bought an other 360° cam. The RICOH Theta S. This thing is much better.
