Ear speaker addational crackling sounds during calls
Omar16
My New xperia XA have a problem of making noisy crackling sounds coming from the ear speaker during making calls. I run diagnostics for the ear speaker and I found it working well. So where is the problem So I can fix it thanks in advance
2 REPLIES 2
Uliwooly
@Omar16
Test the phone in >>> safe mode but it could be network related.
Jonas
Master
Hi @Omar16,
I'm sorry to hear about your phone. Slightly_frowning_Face
Have you had the time to try your phone in safe mode that @uliwooly recommended? If so, did you experience the same behaviour when making a phone call?
If you did, I would recommend that you change the preferred network type in your phone and see if you are able to hear the noise when making a call with GSM only.
Go to Settings > More > Mobile networks > Preferred network type > GSM Only > make a few calls and see if there is the same noise or not.
Let us know how it went! Slightly_smiling_Face
