I do not own this post or whatever, just sharing.
Guys, can anyone try this rooting method and report back? I was not
able to bring my USB cable at work so I am not able to try it now.
STEPS
SOURCE
[P/Go][ROOT] DooMLoRD Easy Rooting Toolkit (v14) {perf_event exploit}[20130624]
XDA Thread Link http://forum.xda-developers.com/showthread.php?t=2335992
Thanks to DooMLoRD from for the method
Thanks to eswawan for sharing it first in the Xperia Go Android Development XDA page.
Hope this helps and hope it works. :smileygrin: :smileygrin:
MODIFICATIONS AFTER ROOTING
I added this because I want to share what I and you have done with the Doomed XGo
phone after rooting. Please let me know what you have done too so that we can add
them to the list below. THanks
1. Modified the Phonebook, Phone and the Messaging app with DARK Themes
click here originally by jatinrungta from XDA
2. Debloated [JB Update] [6.2.A.1.100] List Of Apps/Bloatwares That Are Safe to Delete. Thanks to taboo5200 for the safe list :smileygrin:
3. Installed Root version of greenify to save battery and RAM. Check here
I will add more if you tell me so. :smileygrin: :smileygrin: Thanks
Sir Maam why i cant delete the apps you post but my my phone is already rooted...???
hi
how did you guys delete bloatware and what did you delete to free up ram
plus do any of you guys know how to fix the app 2 sd problem
Hello guys, I have a problem on rooting. I have 6.2.A.0.400 not 6.2.A.1.100 and can't root it since this root kit only supports 6.2.A.1.100.:smileycry: Is there some easy way(2,3 clicks kit :smileyhappy:) that would change firmware version?
PS: I've also tried to update it via PC Companion but no luck, it says it's up to date.:smileyplain:
Thanks for all replys,
Tommy
Edit:
Well, I've flashed my firmware to 6.2.A.1.100 and root it with no problems.
Message was edited by: Tommy991
Hi iaamlard,
For you to be able to delete bloatwares of apps that you
do not need, you need to install root explorers apps
(such as ES File managers and Root Explorer) and
allow root access to that root explorer app.
Thanks,
Eljun
Installed greenify the root version.
Helped in saving battery by forcing applications to hibernation.
Also helped save much RAM.
You guys who got doomed might be able to find greenify very very useful.
Check it out here.
https://play.google.com/store/apps/details?id=com.oasisfeng.greenify&hl=en
Cheers!
i successfully installed the Phone and Contacts into black but fail to do so for Messaging, any idea? Thanks 😃
What seems to be the problem? Did you follow all the instructions properly?
I copied the extracted 'Conversations.apk' into /system/app. Everything went fine up to the apk accession part and after i tap Install, it states that "App not installed", many thanks
