You should contact your Local support to get it inspected, are you using a wall charger? is it Sony's original wall charger?
I suggest that you take a look at the following link to see if you can find any tip:
/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874
You could also post a screenshot of your battery usage when you have around 5-10% battery left and we can look closer into it. You can find the battery usage via Settings > Power management > Battery usage.
It was repaired and it takes a whooping 2 days to charge? You need to change your charger or USB cable then.
When the phone is powered off and you charge it, it should approximately take 3 hours to charge it full. So yes, it may be something faulty with your charger/USB-cable.
