problem with Z2 and dualshock 3 wirless detection
peekskill
hi i have an Xperia Z2 and i have a little problem with the dualshock 3 ... when i use the conectivity setting to pair them it says that it's paired but once i rempve the wire the dualshock3 goes off and there's no BT connection between them the DS3 works perfectly wired and works perfectly when i reset it and use it on a ps3 wired and wirlessly i made i reset to the DS3 before using it on the Z2 but nothing happened the Z2 BT works perfectly when i exchange files with other people ... thanks everyone Slightly_smiling_Face
Tags (1)
13 REPLIES 13
peekskill
this is the problem it doesn't work once i'm in the last step where i should remove the wire and press the PS button to connect wirelessly it doesn't connect the DS3 goes off
Uliwooly
Is this an original Sony DS3 or another brand?
peekskill
sony DS3 as i said it's working with the ps3 perfectly
Uliwooly
peekskill
your idea gave me some hope because i didn't try that but now my hopes are broken Slightly_frowning_Face still the same problem in safemode
Jake-SonyXperia
Champion
Hi Peelskill,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Do you have another controller you can test with?
peekskill
no it's the one i have it's the DS3 i had with the PS3
thank you
Shorminneo
Mine doesn't stay paired after the lollipop update. It keeps asking me to pair it with the standard bluetooth passcode thing which is impossible to do on a DS3 controller.
