Screen problem z2, screen going up and down when "pushed" in
Blejs
Hello, so basicly my problem is like this.
When i press a finger towards the screen and try to say browse down or up slow, the screen can flicker and go up and down or "wabbling". Its possible tho to just swipe up and down without having the finger pressed, but thats harder to deal with. Since it can be to big jumps when reading stuff.
This however doesnt always happen, so sometimes it works just fine. But more or less its causing problems often, and very frustrating to browse/surf.
7 REPLIES 7
dandy63
Leader
Hi, do you have Glove Mode enabled........
Blejs
I tried with glove mode and without glove mode, it is no diffrence.
dandy63
Leader
Any screen protectors.......does it also do this in Safe Mode....link below Thinking_Face
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Phy
Legend
Legend
Try repairing it with Sony PC Companion.
http://support.sonymobile.com/us/tools/pc-companion/
Blejs
no screen protectors, in safe mode it seems to work perfect.
Blejs
It seems to work fine now, after i removed like all pictues/movies and just emptied up space. And did that safe mode, and restarted it, just before that i emptied up space.
Weird if that was the thing, that it was low on storage or something and that lead to the problem, i had less space before and never had that issue earlier.
dandy63
Leader
Hi, try running your phone for a while in Safe Mode......possible cause could be some 3rd part app affecting your phone, you could try narrowing it down by thinking of fairly recent apps you've installed.....as i said, run it for a while and see if your phone works fine :smileysmileywink:
Then it will be a matter of deleting or force stopping each individual app one at a time and testing after each time :smileysmileythumbsup:
