tried doing it in my z2 disbaled the firewall and anti virus but still get the same error :S:S
For me the issue was that ipv6 was disabled under my Local area connections. I just clicked the check box for my network adapter and turned it on. It works after that.
I have the same problem! Before Lollipop comes, i did all the latest updates for Android kitkat and it works normally, but for Lollipop, The sony Mobile Engine won't work, they told me that Sony stopped it and make it payable. I tried many solutions, IPV6, connection, Anti virus, nothing worked
so desapointed !
anyone can help i am facing the same fxxking problem is so annoying and frus.
Hello,
i solved this problem by doing this:
Go to the PC Companion Settings, Internet Options, Proxy Settings. Check the Automatically detect proxy settings and press the Test button. A pop with the text "These settings are correct." will appear. Press Ok and close the settings window.
Try again and maybe will work also for you guys.
have fun.
OG
