Greetings,
I have almost lost it with my battery. First, it used to stay for more than a day... no problems. Then it began to last all of a sudden for about more than half a day which i didnt have a problem with. I updated to Lollipop and it began to last around 14-18 hours which was okay but another update was released after the major update which completely killed the battery life. I tried fixing using PCC and it even became worse lasting only 7-12 hours with moderate usage. What do I do now?
Thanks.
We can't say as you haven't posted an image of what's using your battery only the graph - Also I see your phone is nearly always awake and your signal strength at some times is using more power than normal which is normally because of poor signal strength
Seems that your email app is constantly on and searching
and Snap chat is on alot also
I can also see some 3rd party apps there (battery doctors and so on). Why don't you try to remove some of them and see how it goes?
I also noticed you had some problems before:
/t5/Xperia-Z3-Compact/Battery-drain-after-5-0-update/td-p/962089
But I have never played with the settings. Only after updating I saw this mail app beginning to take loads of battery. What's the reason? I also can't seem to force stop it.
I will remove some recently installed apps and reply asap.
23.1.A.1.28
