MASSIVE overnight battery drain!
Kovacs1
Please see the screen shots, what on earth is going on?! I have had the phone less than a week. Screenshot_20180823-070641.png
8 REPLIES 8
kajaljk
Hi, I am facing the same problem, any solution please?
saurus3009
same here, it happend after the latest update
Kycpokemon
What version are you using? Did you wait for about 2 days for the phone to optimize itself? The phone usually takes about 1-2days to fully get used to the new software.
SpyrosFgs
I have the same problem with mine after the latest update. I used to go to sleep with 100% and wake up with 100% and now I go to sleep with 100% and sometimes in is close to 80-85%
Kycpokemon
If you don't mind, you can on Airplane Mode before you sleep, and then turn it back on when you wake up. This has 2 benefits, Sound notifications won't disturb you and You are less likely to use your phone.
Smyri
Same problem here. Battery is drained after night without any obvious reason. Tried to reboot, but same problem at the next night.
sayyr
Go Airplane Mode at bedtime
If you're caught charger-less overnight, killing all connectivity – Bluetooth, cellular, Wi-Fi, GPS - will help your battery last till morning. Plus, it helps avoid that insomnia-causing blue light. prepaidcardstatus
seamy
  1. Check which apps are draining your battery. ...
  2. Uninstall apps. ...
  3. Never manually close apps. ...
  4. Remove unnecessary widgets from the home screen. ...
  5. Turn on Airplane Mode in low-signal areas. ...
  6. Go Airplane Mode at bedtime. ...
  7. Turn off notifications. ...
  8. Don't let apps wake your screen.
official website
