I would like to know if any other people using the XZ1 Compact (+Android 8.0) experience funky behaviour regarding their sd card in apps like Spotify, Netflix, Google Play Music, ...?
For example: Spotify doesnt even recognize the sd card. So downloads just hit the phones storage with no option to select the sd card. Netflix has the identical issue; I can only select internal. Google Play Music lets me at least choose the SD card in their settings but the moment I pick the sd card option the app just crashes.
Amazon Music displays the sd card but with a capacity of 0.0 GB (even though it was formatted a second ago).
Things like the camera app saves the data to the sd card as expected when I changed the setting.
What is going on here? Is this a known issue? Anyone else experiencing this behaviour?
Byebye
Michael
What I've done so far:
- Set the storage permission manually
- Reformat within the phone settings (multiple times)
- Uninstalling - Wiping App Data - Reinstalling
- (Re-)Partition the sd card with exFat (I use a SanDisk Ultra 128GB microSDXC Class 10, U1, A1, FFP)
The usual stuff which did not solve anything.
Initial setup was, that I've got the phone brand new and let it boot up without the SD card then do the setup bits. Then insert the brand new sd card and let it format thru the phone. Enable sd card encryption. Which lead to the situation mentioned above (card is not recognized at all)
What I've done now is to factory reset the phone with the sd card inserted and boot and setup the phone with the sd card in place this time. Then format it again thru the phone (I have not activated sd card encryption yet) and all of a sudden spotify, netflix, ... work with the sd card just as expected.
So perhaps one of you, who experience the same thing, might want try out if this is reproduceable.
- Keep the sd card in the phone
- Factory reset (I did it via the Xperia companion desktop software)
- Boot it up again
- Format SD Card
My sandisk class 10 64 card is just fine. Sportfy recognizes it and an my music are all in sd card. try formating your card on the phone...
I am also having the same issue. Spotify, Audible, Player.fm...
Only the camera has been able to save to it.
I've tried formatting several times on the phone and on PC.
My sd card works fine with Amazon Music. Cannot check others. SD was used in Z5c before and not re-formated again.
Is it recognized by XZ1c System? Did you grant access rights for these Apps?
I'm experiencing the same crash in Google Play Music with a 256GB SanDisk class 10.
Reformatted several times in the phone with no success.
tryto grant permission on the app
- Boot it up again
- Format SD Card
Yeah, doing a factory reset with the SD card inside fixed it for me.
I'm a bit annoyed about having to set things up again, but hey, at least it was fixable.
Another thing guys, on developer hidden menu, there is a option to enable "force permission on external SD card".
That might also helps for those who has problems...
Hi, I have a little problem with my sd card too. I have a SanDisk Ultra 128GB microSDXC Class 10, previously used in a Z3 compact, I reformatted it before installing in the XZ1 compact. I put the sd card in the phone before using it for the first time, and than I formatted it again in the XZ1 compact.
I set the camera app to save videos and pics directly on the sd card, but when I end recording a video it often says that sd card is not available. The video is actually saved on the sd card, but the app cannot display the little preview on the bottom, and after that at times I can't use the app to take other pictures or videos because it says that the sd card cannot be found. I have to restart the camera app, and at times the error pops up again before recording or taking pictures.
Is anyone else having the same issue?
I have no problem saving videos from Netflix directly to the sd card, or listening to music I saved in it, so I think it could be a problem of the camera app.
