Battery not charging properly
sparkus88
I'm charging my phone and it has gotten to 75% and not the charging symbol is appearing and then disappearring every couple of seconds. I have restarted the phone, tried charging in both a dock and directly in the mirco usb port but still the same problem. I was going to try a factory reset but hoping to avoid this. It seems to be only happening since the lollipop update. Any suggestions?
Thanks
1 ACCEPTED SOLUTION
Uliwooly
It'll be wise to reinstall lollipop
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
9 REPLIES 9
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
Phy
Legend
Legend
are you able to charge it 100% while on safe mode?
How to boot on safe mode.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
sparkus88
Thanks
I tried it in safe mode and have the same problem except it happens at 71%. Is there a simple way of reinstalling lollipop without a factory reset?
Hudini
Try usb debugging
sparkus88
@Hudini wrote:
Try usb debugging
can you be more specific, what do you mean?
Phy
Legend
Legend
you should try contact Sony Xperia Support.
http://support.sonymobile.com/global-en/contactUs/
profile.country.HU.title
Dtomi1972
Hi! Usb cable should try to change.I had this sort of problem...
sparkus88
I spoke to support they said repair the update via PC companion, which is basically just a factory reset and reinstall update. It didn't work still stopped charging around 75% he last few times I charged. I was going to try them again today but when I woke up this morning the battery had charged to 100% so don't know what sorted it.
Uliwooly
Probably an app acting up
@sparkus88
